Thread: cogging
cemetery gates
01.04.2008, 11:43 PM
FYI: It's not the number of poles per se that the MM has trouble with, it's if the motor uses a slotted stator (basically means if each coil is wrapped around a metal "core" as opposed to an "air core", like the Feigaos). Neu motors and the Novak motors are slotted stator motors, so both can have issues with the MM ESC. This can be overcome with some conservative gearing and/or changing some of the settings in the ESC though...
I can attest to this, my MM with a neu 1515 and a novak hv6.5 both have pretty bad start-up cogging(can not nail it from the get go). But, I just put in a mega ACn car motor(4580kv) which is a 6 pole and can absolutely nail the throttle from a dead stop and have no cogging at all. It runs as good as novak sensored motors and esc if not better(meaning more torque).
Bye
