DrKnow65
DrKnow65's Avatar
01.05.2008, 08:41 PM
The MM will not work when the radio voltage is not the same as the bec voltage inside the MM. The MM uses it's own bec to run the circuit board so the radio voltage has to match it or it doesn't recognize the signal.
