Originally Posted by DrKnow65
http://www.rc-monster.com/forum/showthread.php?t=9368 and mabey I can find the other tonight.
No problems with a ubec (@5v), just with reciever packs.
When you disconnect the red wire and run a ubec, isn't the "brain" potentially looking for a certain 5-0v, 1-2ms signal? What if your radio was over 5 volts, couldn't the brain not see a proper 0 volts on the bottom of the square wave?
As long as signals TTL-compatible - no problems, referenced via ground.
