squeeforever
squeeforever's Avatar
01.08.2008, 07:33 PM
I'm still thinking about getting one of the TCS setups. I think it would work decent, but I guess the only way to find out is try it. The main advantage I see is a cooler running system, if only slightly, which could allow you to have a wider array of gearing choices. Maybe use something like the 9920 marine and make use of the tubes that run through it...I'll probably try one on my BPP LSP. I just might help with heat, since it gets pretty damn hot in the summer around here...
