lutach
lutach's Avatar
01.10.2008, 05:05 PM
I find the humor of your statement lutach. Saying that the mm gets hot due to the fact it is overrated is incorrect. The mgm has superior programming, in that it does not seem to mind what type of motor it runs. Same with the quark, save for a poor heatsink design. The mm is an excellent 2 pole motor contoller, and an amazing value. No doubt that the higher priced and rated escs will work better, however there is no need to buy a 300 esc to run a 2 pole motor on 4s, the mm works just fine for that. I have run mine on a 4 pole plett and had good results, but it is in a smaller/lighter vehicle.
Explain something to me. I ran the MGM 8012 which has no heatsink with the same set up I ran the MM and the MM thermaled a few times and the MGM didn't. Yes, it might be better software coming out of the MGM, but it has a rating that is 20A less then the MM and no heatsink. If someone is on a budget, then yes go with the Feigao and MM. I just wanted to help out in pointing a good efficient sytem.
