Thread: motor choices
nativepaul
nativepaul's Avatar
01.10.2008, 08:28 PM
Feiago 8XL, MM, 4S, 14/44. 10ish min runs on 4350s. The motor gets bloody hot typically around 85degC with the RCM heatsink and 2 fans on it, the MM with 1 fan gets pretty darned hot too 70degC ish. The setup works and is fast but I really want a better motor. I wouldn't mind a bigger ESC too but with my budget I doubt that will happen, it will get a motor upgrade soon I hope tho.
The Feiago/wanderer/nemisis are the cheapest motors that will work, but I think the cheapest motors you will be happy to keep are yet to be identified. I'm going to try a Mega 22/30/2 and see how that goes its a lot smaller than an XL but better quality so the efficiency may reduce the need for the extra mass? They are 6 pole to keep the torque high and are not much more expensive, just hope they work OK with the MM, I get some coging with the Feiago and if it gets much worse it wont be acceptable.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
