01.12.2008, 12:41 PM
Most people seem to find that the 125b does not like a fully charged 6s pack. Once the voltage comes down a little the quark seems to be ok. Since your setup is obviously not drawing a ton of amps, you are most likely not overtaxing the 125b. I havea feeling that the quark is somewhat sensitive to gearing when running on 6s. Too much load and it will most likely have issues, as many have found.
Nice to hear that it is working well for you. If I put the 2826/12 in mine it should run great. Lower kv will load the esc even less, I may be able to get away with a quark 80, instead of the 125b.
Not to hijack your thread, but I just ordered another 125b and a savage ss kit. I also ordered the brushless savage chassis from mike! I may try an out runner in this, as it looks to have some more room, and mech brakes too! alo bought a pair of trakpower gold lipos, a greatplane 60hv esc with prog card, 3 more ccbec, and a sv27 6 pole boat motor to test out. It was an expensive morning! (not really as I have worked a trade with the lhs owner for most of the stuff I got)
Really like the out runner setup you did here sike, looks clean and I am sure that will run well. Are you going to stay with 6s, or step down when the 2 speed comes out? Or are you going for some insane speed!?!
