01.12.2008, 06:12 PM
12nimh= 14.4v, 4s= 14.8v. The MM works fine on 4s, but you need to disable the built in BEC and use a UBEC or RX pack. Simply remove the red wire from the rx lead where it goes into the plug, and tape/shrinkwrap it back onto the cable. Other than that, you should be good to go.
