austinmaxx
01.14.2008, 04:11 PM
Probably I have (2) 8000mah 7.4 2s maxamp lipos and they fit easily and I have to use the little foam spacer they give you for running 6cell packs and there is room for heavy moddding for longer packs if it is needed....I must say it might be alot of weight with that much battery size...do you need that big a batt?
