glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.16.2008, 05:41 PM
Might be a simple as a bad solder connection that "fixed" itself with the handling of it...
but more likely it's a bad cell (internal short that was blocking voltage) that woke up when you hooked up the charger, thus allowing the pack voltage to flow again.
I've seen old packs act a bit like this.. they have cells that drop voltage really low, but the voltage goes real high when charged... I can't explain why... only guess.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
