Sower
Sower's Avatar
01.17.2008, 12:06 PM
Yep, a 3s 5000mah battery and a 6s 2500mah battey should produce the same runtime, if the correct kv motors are employed to produce the same motor speed and the gearing is the same. I have noticed that the hv setup seems to get slightly longer runtimes than expected. I think that boils down to the hv setup being more effecient.
Dude, thanks - that's exactly what I was trying to say. And yeah, I think you're right about the efficiency. Since you're drawing less amps - the heat load is lower and I think it just runs better. At least that's what I'm betting on since I've got a 6s 3900 waiting to go into my XT8.
