01.18.2008, 03:07 PM
You can stop the spark by initially hooking up the ESC through a charging resistor. Once the caps are charged up, you can then hook the batt directly to the ESC. This would be ideal for any setup regardless of voltage or capacitance rating. That initial spark wears out the connections after a while...
