spaz163
Functionality with a dash of Form
spaz163's Avatar
01.20.2008, 11:06 AM
I converted a MBX buggy to BL and I used a 1/4" thick piece of aluminum and had it bent at a 90 degree angle and then drilled it and dremeled it to my liking... works great. I then mounted it to the chassis and to the rear diff support. The motor then sits up higher than the spur. If you want the motor off to the side I can't help you, sorry.
