sikeston34m
sikeston34m's Avatar
01.20.2008, 10:37 PM
Originally Posted by Mod Man View Post
You will still need a roller bearing on the pinion side. Two bearings are needed for proper input shaft support. I was wondering what teh clearance is between teh pinion and the bearing near it. If there is enough clearance there to put a CF or stainless washer there, that would work. Maybe a narrower roller bearing would provide the needed clearance.
I currently have 3 - .2mm shims there right now. It makes the mesh just right.
