JeffEmbracedDC
JeffEmbracedDC's Avatar
01.22.2008, 08:00 PM
Thanks, guys!
Yep, I've ordered a set of 25mm fans and a Novak cap for the battery leads. I plan on leaving the 3 smaller caps alone and seeing what kind of temps I get from there. I plan on mounting a fan on the heat sink and one blowing through the bottom of the case on the fets. Does that sound about right?
Thanks, guys!
-Jeff
Also..
Does this look correct? I have a stock 8ight buggy.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 48
Pinion Tooth Count: 16
Total Voltage: 14.8
Motor KV: 2084
Tire Diameter (inches): 4.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 3 : 1
Total Ratio: 9.92308 : 1
Tire Circumference (inches): 14.14 inches (359.08mm)
Total Motor Speed: 30843.2 RPM
Vehicle Speed: 41.61 MPH (66.84km/h)
Effective Speed Rate: 2.81mph/V (4.52kmh/V)
Effective KV Value: 2084
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Thanks!
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
