Edumakated
01.25.2008, 01:45 PM
Buyer's remorse is understandable when you plunk down serious cash for such a small thing. The Quarks are VERY VERY smooth and run just about everything out there. I love both of mine. Also, warranty is fast and easy from all reports. But, yes, they have heat issues, which can be rectified with a little additional heatsinking. And yes, they don't run at anything over 5s well. So, if these concerns are important enough, then maybe you should go to an MGM.
Thanks. I just don't want to blow $300 and then it not work so hot when I could have spent $375 and been done with it from the start. So is the BEC mod optional? What type of temps are you seeing on your Hyper with 4s? Also, what kind of run time do you get?
I am sure I could figure out how to do it... I just get nervous having to cut wires, etc on these things. Is it easy to do?
