rchippie
rchippie's Avatar
01.26.2008, 08:17 PM
If I understand you correctly, I would think that the banana jacks are for connecting the charger to a power supply. There should also be some kind of harness that goes between the battery and charger like linc said....
There is a cord with 4mm plugs for the power supply out the left side. Then there are 2 banana jacks on top by the jack for the balancing plate.
I just found the online manual for the 610 charger.
http://media.hyperion.hk/dn/eos/EOS0610iNET-MAN-EN.pdf
REAL MEN RUN BRUSHLESS
