knotted
01.27.2008, 04:14 PM
OK, finally got a good fit in the original ESC plate position. Used 5.5mm connectors and ran the wires under the plate. Everything is secure and its not as tight a fit as it looks. There is plenty of room between the caps and the motor (about 2 rch). Going to run the whole thing this evening and see how it goes. Oh, the padding under the ESC heatsink is some thermal CPU tape.
ID:	3887   Click image for larger version
