01.29.2008, 06:38 PM
Well, most aircraft ESCs are meant to use a stick throttle.
- Max throttle (2ms) for a pistol radio is max throttle for a radio.
- Neutral (1.5ms) for a pistol radio is half throttle for an air radio.
- Brake/reverse (1ms) for a pistol radio is min throttle for an air radio.
So, many need something to translate the signal so a pistol radio can be used. That's good that I don't need it! And nice to hear it doesn't heat up even with higher currents (I assume your 127A figure is burst?).
It looks like the HV110 is a winner then!
