Sneeck
RC-Monster Custom
Sneeck's Avatar
08.29.2005, 01:51 PM
The cvd I managed to bent in 6 run's and only high speed corner's whas a ue cvd. I've never jumped in those 6 run's. Rpm arm's are good, but since i'm running 8 spyder's which cost a little to much for me I don't want it to get damaged during a cvd that get's pressed in if the arm's flex to much.
Also a note on the rpm knuckles. The bearing-housesing will wear after time. Do take note of this cause the nylon rpm uses is more a flex-type of plastic, not rigid.
  Send a message via MSN to Sneeck
