Thread: neu vs mega?
lutach
lutach's Avatar
01.30.2008, 11:38 PM
Originally Posted by Revracer View Post
seems to me like $150 for this motor is well worth it. so im looking at probly a ~$250 setup once i get the ESC and motor.whats with the noise though? that sounds different from other brushless motors ive run. its loud too. does that truck have a center diff? didnt look like it but it might have been there. if not then will it not lift up just cause of length and it sits low? can you see it doing wheelies easily without a center diff in a MT? geared for about 45mph?
That truck was in a bad crash. I lost signal and it went straight into a curb. The pinion and spur is not that well aligned and I had to play with it a bit to have them run somewhat smooth. The conversion kit came with a slipper, but I took it out because the spur gear had melted. The spur gear for the Savage is working good so far and it is not a solid center kind of like the one in my BPP truck. When I had the center diffs in my buggy and truck it would still do wheelies, but the unloading to the front wheels afterwards was really messing the tires very fast. Mega makes a strong motor. The magnets are strong like the Neu motors, but the Megas have 6 poles and will draw less AMPs. Keep in mind that electric motors have the uniqueness of getting power from torque.
