01.31.2008, 01:41 PM
what batteries are you planning on using? (capacity)
If you take a look at the site that's in Brian his signature you can see how to wire the UBEC
The initial goal of the UBEC is to replace the heavy receiver battery-pack. Since there is a larger battery available, this voltages needs to be adjusted to the right voltage for the receiver/servo's.
