01.31.2008, 02:33 PM
Yeah, the some of the newer ESCs have built-in UBECs, but the Quark and MM definitely use linear regulation.
And yes, runtime does increase. In a linear BEC, the output current is what is being drawn from the main batteries no matter what the voltage difference is. A UBEC is more of a "power transformer".
For a 5s battery setup and say you have a 3A servo load:
- In a linear regulator, the current being pulled from the main batteries is the same as the current on the linear regulator output, 3A in this case.
- In a UBEC, the current being pulling from the main batteries is only around 1.29A (figuring in a 25% efficiency loss - but it's usually a little better than that). That's less than half the current, so runtime will increase a little.
