squeeforever
squeeforever's Avatar
01.31.2008, 06:31 PM
The mamba's are no good for such a big vehicle. You need as a minimum L-can motors. Go for the Foam tires. Imex has them. Pizza cutters are very difficult to control and are very dangerous. A 10Lbs vehicle going 60+ mph will cause serious injuries and damage, when control is lost.
I would have to disagree. Two Mamba's in a MT will be more than enough.
I would go for either two MM5700 or 6900 setups using Komodo LP tires. There lightweight and won't balloon. If moneys no object though, maybe go with two Neu 1509's with a couple MGM 9012's.
