SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.01.2008, 10:06 PM
I think it can be done. Kind of like what I said before, if one 5lb stampede can go 65 mph with one motor on 3s (the vxl system for example which is close to a cm4600), a 10lb exmaxx should be able to go 65 mph with 2 motors and two 3s packs. Its simple math. Also, I bet Promods 12 nimh cells back then dont even come close to comparing to the capability of the best 3s packs, which you could improve even more by adding cells in parallel. And on 3s I bet one lehner 3100 xl motor will not even come close comparing to two cm5700s for that matter.
Area 52 Ranch Raceway
T.R.C.R.
