02.03.2008, 09:23 PM
Fixed my query... Software option in Monster look like the same as in Mamba under 1.17...
controller.name version_customer gui_name setting_value.name help
Monster Max (F310C) 1.17 Software
Monster Max (F310C) 1.17 Throttle Curve LineColor na
Monster Max (F310C) 1.17 Throttle Curve GridColor na
Monster Max (F310C) 1.17 Reverse/Brake Curve LineColor na
Monster Max (F310C) 1.17 Reverse/Brake Curve GridColor na
Monster Max (F310C) 1.17 Hex55 Value na
Monster Max (F310C) 1.17 MidCount Default na
Monster Max (F310C) 1.17 Cutoff Type Dummy Default na
Monster Max (F310C) 1.17 Brake/Reverse Type Proportional w/ Reverse Lockout For bashing or racing (may not be an allowed setting for racing). The controller must see 2 seconds of steady neutral throttle before it will allow reverse operation.
Monster Max (F310C) 1.17 Brake/Reverse Type Proportional w/o Reverse Racing setting - no reverse enabled at all.
Monster Max (F310C) 1.17 Brake/Reverse Type Forward to Brake To Reverse Similar to lockouttype, but no neutral waiting required before reverse is enabled. The controller will quickly brake the motor to near zero rpm, before allowing it to run in the opposite direction in order to save transmission parts.
Monster Max (F310C) 1.17 Start Power Low Best for almost any application, and any battery type/capability.
Monster Max (F310C) 1.17 Start Power Medium Good for use along with high capability batteries, and light race cars, and some slow systems or rock crawlers.
Monster Max (F310C) 1.17 Start Power High You MUST have top quality batteries to get the most from this setting without the car stuttering if it's set up for high speed. Best used for very slow/heavy rock crawler set-ups.
Monster Max (F310C) 1.17 PWM Rate Dummy Default na
Monster Max (F310C) 1.17 Drag Brake 0%, Disabled No drag brake - car will freewheel in neutral
Monster Max (F310C) 1.17 Drag Brake 10% Lowest drag brake setting - good for bashing, or low traction racing
Monster Max (F310C) 1.17 Drag Brake 20% Low drag brake setting - good for bashing, or low traction racing
Monster Max (F310C) 1.17 Drag Brake 30% Medium low drag brake setting - good for medium traction racing
Monster Max (F310C) 1.17 Drag Brake 40% Medium drag brake setting - good for medium traction racing
Monster Max (F310C) 1.17 Drag Brake 50% Medium/High drag brake setting - good for medium traction racing
Monster Max (F310C) 1.17 Drag Brake 60% Medium/High drag brake setting - good for medium/high traction racing
Monster Max (F310C) 1.17 Drag Brake 70% High drag brake setting - good for high traction racing
Monster Max (F310C) 1.17 Drag Brake 80% High drag brake setting - good for high traction racing
Monster Max (F310C) 1.17 Drag Brake 90% Very High drag brake setting - good for very high traction racing
Monster Max (F310C) 1.17 Drag Brake 100% Very High drag brake setting - good for very high traction racing
Monster Max (F310C) 1.17 Drag Brake MINIMUM na
Monster Max (F310C) 1.17 Drag Brake MAXIMUM na
Monster Max (F310C) 1.17 Drag Brake INCREMENT na
Monster Max (F310C) 1.17 Punch Control 0%, Disabled No accelleration limiting. The accelleration will be 100% determined by thr capability of your battery pack to flow power and maintain voltage.
Monster Max (F310C) 1.17 Punch Control 10% Very low accelleration limiting - good for 4wd on high traction surfaces
Monster Max (F310C) 1.17 Punch Control 20% Low accelleration limiting - good for 4wd on high traction surfaces
Monster Max (F310C) 1.17 Punch Control 30% Med/Low accelleration limiting - good for 2wd/4wd on med/high traction surfaces
Monster Max (F310C) 1.17 Punch Control 40% Med accelleration limiting - good for 2wd/4wd on med/high traction surfaces
Monster Max (F310C) 1.17 Punch Control 50% Med accelleration limiting - good for 2wd/4wd on med traction surfaces and offroad
Monster Max (F310C) 1.17 Punch Control 60% Med/High accelleration limiting - good for 2wd/4wd on med/low traction surfaces and offroad
Monster Max (F310C) 1.17 Punch Control 70% Med/High accelleration limiting - good for 2wd/4wd on med/low traction surfaces and offroad
Monster Max (F310C) 1.17 Punch Control 80% High accelleration limiting - good for 2wd/4wd on low traction surfaces and offroad
Monster Max (F310C) 1.17 Punch Control 90% High accelleration limiting - good for 2wd on low traction surfaces and offroad
Monster Max (F310C) 1.17 Punch Control 100% "High accelleration limiting - good for 2wd on low traction surfaces and offroad, very good setting for ""easy on parts"" style bashing."
Monster Max (F310C) 1.17 Brake Amount 10% The brake will engage at a strength 10% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 20% The brake will engage at a strength 20% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 25% The brake will engage at a strength 25% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 30% The brake will engage at a strength 30% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 40% The brake will engage at a strength 40% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 50% The brake will engage at a strength 50% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 60% The brake will engage at a strength 60% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 70% The brake will engage at a strength 70% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 75% The brake will engage at a strength 75% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 80% The brake will engage at a strength 80% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 90% The brake will engage at a strength 90% as strong as the strongest brake setting.
Monster Max (F310C) 1.17 Brake Amount 100% The brake will engage at full strength.
Monster Max (F310C) 1.17 Brake Amount MINIMUM na
Monster Max (F310C) 1.17 Brake Amount MAXIMUM na
Monster Max (F310C) 1.17 Brake Amount INCREMENT na
Monster Max (F310C) 1.17 Reverse Throttle 10% Reverse throttle will be 10% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 20% Reverse throttle will be 20% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 25% Reverse throttle will be 25% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 30% Reverse throttle will be 30% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 40% Reverse throttle will be 40% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 50% Reverse throttle will be 50% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 60% Reverse throttle will be 60% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 70% Reverse throttle will be 70% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 75% Reverse throttle will be 75% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 80% Reverse throttle will be 80% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 90% Reverse throttle will be 90% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle 100% Reverse throttle will be 100% as strong as full throttle.
Monster Max (F310C) 1.17 Reverse Throttle MINIMUM na
Monster Max (F310C) 1.17 Reverse Throttle MAXIMUM na
Monster Max (F310C) 1.17 Reverse Throttle INCREMENT na
Monster Max (F310C) 1.17 TransmitterCalLabel Transmitter Calibration na
Monster Max (F310C) 1.17 MinCalLabel Full Reverse na
Monster Max (F310C) 1.17 MinCalLabel Tx Min Default na
Monster Max (F310C) 1.17 MidCalLabel Neutral na
Monster Max (F310C) 1.17 MidCalLabel Tx Mid Default na
Monster Max (F310C) 1.17 MaxCalLabel Full Forward na
Monster Max (F310C) 1.17 MaxCalLabel Tx Max Default na
Monster Max (F310C) 1.17 Throttle Dead Band Very Small (0.0250 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Very Small (0.0375 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Small (0.0500 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Small (0.0625 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Small (0.0750 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Average (0.0875 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Average (0.1000 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Average (0.1125 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Large (0.1250 ms) na
Monster Max (F310C) 1.17 Throttle Dead Band Large (0.1500 ms) na
Monster Max (F310C) 1.17 Motor Type Brushless Use this setting to run any brushless (3 motor wires) motor.
Monster Max (F310C) 1.17 Motor Type Brushed Reversing Use this setting to run any brushed motor, and have access to reverse.
Monster Max (F310C) 1.17 Motor Type Brushed High-Power Use this setting to run a brushed motor in foreward and brake only mode for racing.
Monster Max (F310C) 1.17 Arming Time 1 second Wait for 1 second of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 1.5 seconds Wait for 1.5 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 2 seconds Wait for 2 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 2.5 seconds Wait for 2.5 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 3 seconds Wait for 3 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 4 seconds Wait for 4 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Arming Time 5 seconds Wait for 5 seconds of neutral throttle before arming.
Monster Max (F310C) 1.17 Cutoff Voltage No Cutoff Best for racing with top quality discharge NiMH or NiCad packs. DO NOT USE this setting with Lipo packs
