DrKnow65
DrKnow65's Avatar
02.04.2008, 12:48 AM
The switch wires go on the bottom side of the board, just between the red motor wire and the positive battery wire, opposite side of the board from the led's. Polarity is not important, it only makes or brokes the circuit. The black switch lead is closer to the red motor wire, if I remeber correctly. Both of my MM's have had the switch removed and the connections "bridged" with a bit os solder. (you can just get to the two pads for the switch wires with the MM assembled in it's case).
