02.05.2008, 09:00 PM
Yep, a bit of loctite or CA glue will work, but you want the watery type so it will 'wick' into the tiny gap between the can and endbell (capillery action). You could also screw the end bells on like how the MM/ Velineon motors are assembled- a more solid method probably.
