Good For You.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Good For You. - 02.08.2008, 01:36 AM
Hey Sikes great go on teh gears for the damaged servo gears. We expected at least that much for the problems you had. Of course now you know they will not hold up in your rig with that motor. As far as the MG995's I have not tried them either, but like stated earlier for $22 what have you got to lose. We do hope that you have better luck with the diff gears setup the other way. It would be nice if you could get this thing set up in a configuration that will allow you constant use without failures. Good luck with the changes and keep up the good work.
