BlackedOutREVO
02.09.2008, 02:52 AM
Originally Posted by Serum View Post
I use M3, M4 taps, scroll saw, rasps (different grades), dremel, drills, scotch brite/waterproof sanding paper, calipers, ruler and some patience.
Easiest thing to do is to draw something, and print it 1:1; that way you can simple put the 'template' on the aluminum with double sided tape and cut away the stuff that's in the way.
A vice is a handy tool too. As is a press drill, but you can manage without both.
you are able to make parts like this fair easy;
Thats just showing off Serum
Thats amassing!
I need some tools so I can work with alu
