espeefan
02.10.2008, 05:37 PM
My RC Monster hybrid diffs don't drop in with the bulkhead halves assembled. To explain it further, the differential cases have what I'll call 'ears'. The ears are where the screws bolt the two case halves together.
The Revo bulkheads have a fairly large clearance notch near the bottom, where the differential case's ear can fit, but at the top of the bulkhead, this clearance notch is nearly non-existant. It's the ears of the diff case that don't have enough room to allow my bulkhead halves to squeeze together, but just at the top.
I wouldn't say the differential case is to wide. I would say the bulkheads don't have provisions for the ears of the case to fit at the top, but the bottom is okay.
This is why I am wondering if anyone else has needed to dremel the bulkheads a bit to fit. Not a big deal if I have to, and it doesn't look like I need a lot of room. Just a little bit more.
I've taken 2 photos to further show what I mean.
If you look at the photos, you'll see the ears of the diff case hit bulkhead instead of having a slight recession to drop inside. The bottom is just fine. It's only the top that seems to lack the room.
