Pedebeater
Pedebeater's Avatar
02.11.2008, 05:27 PM
There is a way to get the shaft to come out on both sides. You need to take the motor apart and slide the shaft down, you also need to make a new flatened space on the shaft for the grub screw to grip onto. You can also use a prop adapter, but I will not be doing it that way.
You can ask Takedown for more info on that procedure.
Faster than a cheetah on cocaine
  Send a message via AIM to Pedebeater
