its me
There is no help for me... I'm addicted to R/C
its me's Avatar
02.11.2008, 10:33 PM
Motors depends on your budget really, but a couple L can sized items would be plenty of poke for a 10lb truck or there abouts. Im thinking maybe feigao 10L motors with MM escs, or for a more upmarket setup what about some Neu 1509s and MM escs. The voltage you decide on will better determine the exact motor choice and gearing, but its a very simple calculation thanks to BrianG.
Again thank you neil! ive been playing with the calculator trying to figure out what to use, ive read what I can on the subject and seen issues of heat. I also think im going to run 3-4s per motor. tahnks again for the help.
BTW what do you think would be a better set up? 5700 maba's or the 10Ls the nue set up might be out of what im willing to spend on this truck :), maybe ill change my mind later but this truck is going to bashed.
rccna.com
