02.12.2008, 01:24 PM
Originally Posted by its me View Post
Again thank you neil! ive been playing with the calculator trying to figure out what to use, ive read what I can on the subject and seen issues of heat. I also think im going to run 3-4s per motor. tahnks again for the help.
BTW what do you think would be a better set up? 5700 maba's or the 10Ls the nue set up might be out of what im willing to spend on this truck :), maybe ill change my mind later but this truck is going to bashed.
I would say to run a pair of 9l motors on 3s lipo each. That would be a killer setup that should run cool. That also means that you do not need a ubec, just disable one of the mm internal becs by removing the red wire. Plus batteries would be cheaper too.
You could run a pair of the traxxas vxl systems, but I think the motors are too small.
