sikeston34m
sikeston34m's Avatar
02.12.2008, 06:44 PM
Well the AXI 2826/8 motor came in. I got it installed.
Took it outside to try it, and I can't tell anything really. It's been storming ice here for the past two days. My dirt mounds are hard as a rock and all the maxx wants to do is spin and throw ice chunks around.
On the brighter side, it does appear to be alot more aggressive with this motor. It's going to power it really good. The only thing I'm curious about is motor temps.
@Linc,
Where did you get those heat sinks you had attached to the Monster Pro I got from you? What did you glue them with?
I'm thinking about installing a square heat sink over the open mounting hole in the motor plate, then attach a 25mm fan to it. This will help with temps in the motor AND clutch department at the cost of only .5 oz.
