jhautz
jhautz's Avatar
02.12.2008, 08:11 PM
Perhaps a delayed LVC is not a good idea. If it allows the batteries to drop below 3v a cell, even for a split second, it may be enough to do damage to the batteries (or at least shorten their life considerably).
I'm with you on this one. If the battery is dipping below the 3V/cell mark then the battery isnt up to the task and you will be damaging it if you run it this way. Gear down to reduce the load to a level that the battery is capable of supporting or get a better battery.
I say this with the exception of the MGM controllers which just flat out have much to sensative of a LVC.
to make it...
or break it...
Silent...But Deadly
