02.14.2008, 01:46 AM
Personally a pair of 7xls will be overkill to play with. For all out speed you need power, to play you will most likely be happy with a combo that can put out 1.5 hp continuous. A pair of 15l feigaos on 5s lipo would be plenty of power (at least 2hp), and would run good temps as well. Battery cost and weight is a consideration, but a pair of 3000mah 5s 20c lipos would be plenty for that setup. A pair of quark 80 amps escs would be a good choice for that too. You are looking at a decent amount of cost, but I am sure that you would be happy with the result.
