tom255
tom255's Avatar
02.15.2008, 04:41 AM
Potreinas
Conclusion... is this esc forward only with "drag brake"? I have to use mecanical brakes? or is posible to configure it to use the motor brake when y brake with the radio ( not when I leave it in neutral).
Exactly! Its plane ESC and plane ESC dont have any other brakes. For plane trottle lowest position is brake and plane ESC arms only in that position! No chance to programm to other way.
Only option is to use additional servo with Y cable for barake
Governor mode for Helis, ESC holds constant speed no mater of load of motor.
Then Heli change pitch on his blades to fly higher it loads the motor and RPM usualy goes down, Governor mode try to compensate RPM's
