tashpop
02.17.2008, 09:34 AM
Originally Posted by jefierro View Post
How many teeth is in that pinion you R using?
would this work on a HV4.5 on 12 cells?
i see no reason why it wouldn't. remember that this takes away the transmission, so gearing will be way different than it was before. you'll use setups simular to what the truggys uses. make sure to use the speed calculator to get the gearing right.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
