wallot
wallot's Avatar
02.17.2008, 04:13 PM
u put brake servo on channel 3
you mix channel 2+3
you set channel 2 BR EPA on radio to 0 (so ESC does not do anything when u push brake)
you set channel 3 FR EPA on radio to 0 (so nothing happens when you push throttle)
and on ESC you either disable braking if possible or set it to lowest setting
of course you will loose reverse.
good motor/ESC can stop 5kg truck - my Neu + MGM can stop my maxx without any issues and i have to have brake EPA set to 75% as anything higher is just too much
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
