hobbimaster
02.17.2008, 09:30 PM
potreinas, Did you try EPA settings 120% Forward and reverse? Once I did this the instant braking at times of neutral stopped. You have to recalibrate your ESC to your TX radio after making these adjustments.
Yes, I was running it in lipo cutoff mode, 4s cutoff to be exact. What doesnt make sence is that my Orions are only 15C, while guys on here are running much more powerful batts. I would have thought LVC might start acting up, or when I was giving it WOT to try to get the over current protection to kick in like MGM has suggested. I guess only time will tell when guys start getting them back from repair if it worked out or not.
I do like the idea of being able to down load the most current version of SW. I wonder why the ESC must go back in? Isnt it more of a software update like castle puts out? I would think if you already have the USB and PC it could be easily done.
