02.18.2008, 12:27 AM
Originally Posted by squeeforever View Post
The best way you could probably do the RWD/4WD would be just like how they add front dig to crawlers. Just gotta figure out a way to make it stand up to the power. RCCA had a article about how to add front dig in a issue a while back.
I was thinking a similar idea, just inside the tranny. The gear set would have to be mored to the rear, to facilitate room to place the disconncetor for the front drive. My only issue with that is that the front diff will be rotating the entire time, connected or not to the tranny. Some sort of disconnect at the wheel hub would be good as well, but would be a bit too much on a rc vehicle. I may disassemble the emaxx tranny and see if this would be feasable.
