02.19.2008, 09:25 PM
Personally, balooning receivers is the best option, and is the easiest option to remove if you need to work on something (like a broken antenna wire). But, show-goo should work fine since there are no heat producing parts in them. Just make sure not to get the goo in the output pins.
