Originally Posted by Sammus
That would be cool thanks.
Ok, using the stock strap, a 105mm long battery will be the max. If you make another strap, or used an old emaxx strap you could fit a 135-140 mm long pack, as the chassis has enough holes to do this. Yo would not be able to put the esc behid the battery with a longer pack. A velcro strap would also be an option, like the gmaxx straps.
