jhautz
jhautz's Avatar
02.21.2008, 04:40 PM
The older MM units will arm on 5s. The newer ones will not. The version of sotware doesnt matter from what I understand. Its in the controller itself.
If you have a new one I believe that you may be able to make it arm on 5s by turing off the LVC. I dont know this to be true becasue I dont have a newer MM to test it with, but this is what I have heard on the board here. If you try it and it doesnt work then you will likely need to get a ESC that was designed to work with 5s if thats what you need. Or possibly find a used older style MM.
to make it...
or break it...
Silent...But Deadly
