02.23.2008, 08:28 PM
That is very interesting!
i am in te process of making a very similar buggy using emaxx chassis components. My chassis will be a welded steel tube affair, with lots of cross bracing and a solid skid in the center.
I am still in the design phase and an trying to get a good chassis design figured out. I may even fab up a sheet steel box section that will run from the front bulk to the rear, and then weld some outrigger tube sections to that. Or it may be all tube with a sheet steel center skid (prefered design).
I am going to go with a 4wd setup most likely, and use a center diff. That way I can have fornt and rear mech brakes and use a kb45 motor on 8s-10s lipo. Need a big motor to move this beast around!
