Originally Posted by lincpimp
Well, from my extremly limited knowledge, the brain has to have some sort of regulated voltage. An opto isolated esc does not have the current ability of a bec built it, but must have some sort of regulated supply for the brain. Time for the smart people to tell you what to do.
How about I eliminate the onboard bec, then just feed the Brain "through" the red wire from the external bec?
Sounds like I would have to keep the external BEC set at 5 volts though.
Hmmmmm..........
