lutach
lutach's Avatar
02.25.2008, 06:20 PM
Originally Posted by strodedawg View Post
i understand that using a higher voltage lipo yields less amp draw, which yields lower temperatures. what i am cofused on is that i can use a lower C rating and less mah and still get the same run time?
any info would help
can't wait for the mmm
I run 20 minutes on my 6S 2200mAhpacks without an issue. One of the reasons why it would've been good for Castle to just do a 12S capable controller. They have the MM that can handle 4S so why not have the MMM handle 12S. I think they would finally have a complete line of ESCs. The math is simple. If you have a 2000 Watt combo you would draw 90A on 6S, 54A with 10S and 45A with 12S to get the same amount of power. With higher voltage you will also have to go with a smaller pinion and/or larger spur. Another option would be to use the 4.3:1 diffs that some truggies have in your buggies.
