02.29.2008, 09:17 AM
With a huge amount of power the center diff will not stop wheelies. I do think a center differential is the way to go. The center diff will weigh less and have less rolling resistance than a transmission. Also you can have some crazy high gearing with a center differential.
If you will be using 2wd or worried about power loss just get a spool for the center diff. Ofna makes one for there center differential.
My trucks were always faster with a center differential. Not sure why, could have been the less rolling resistance or the higher gearing.
Promod
IF it's cogging your not pulling the trigger fast enough!!
Brushless from the Start!
