rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.29.2008, 03:24 PM
List of compatible Parts: MQ vs Rage
- upper arms
- lower arms (with slight modding... need to make the hinge pin holes larger)
- turnbuckles
- bumpers
- wheels and tires (w/ 12mm hex on MQ)
- shocks
- knuckles (but not the bearings)
- outer steering column.
- motor mount
- gear pitch
- battery brace (Rage to MQ is ok, but MQ to Rage will not work. MQ battery brace is actually 5mm too short to fit on the Rage)
List of Non compatible parts:
- Diffs (everything... input pinion, ring gear, etc)
- Diff cases
- Main Drive shaft
- Spur gear
- Driveshafts
- Main Chasssis
- Shock Towers
- Tower Brace
I'll be keeping this list up to date as we find out more. If you see anything on that list that needs updating, please let me know.
rcm xt8
rcm xb8
rcm crt.5
